Making a dash/ taking original cluster off?
NBraun
Well, I'd really love to make a dash using my original tach and oil/neutral/turns, but im worried, all the wire connect in the headlight, obviously, but im unsure of how i can do this. Most of the wires go to the cluster, but i can't find them on the diagram. Any tips on wiring this new dash? Im seriously not sure how to do this.
Your question doesn't really make sense. :)
Sounds like step one is to familiarize yourself with a wiring diagram:
http://www.instructables.com/id/HOW-TO-READ-CIRCUIT-DIAGRAMS/
I assume you have a wiring diagram for your Honda/Suzuki/Yamaha/Harley/Kawasaki/Ducati/Aprilia/Moto Guzzi/ from some year that your model was made?
Can you trace the wires from the existing connections? Write down the colors?
Hard to help without knowing a model and year of the bike, and without a specific question....
get a wiring diagram and write down which wires go to what and what they do
ie:
the headlight indicator will just be wired into the high beams, so when they are on the light is on, but the neutral light will be a ground circuit, so youll want a hot lead and then ground through the neutral switch.
then just replace the stock lights with whatever lights you want to use.
There's a GS750 manual here which will have a wiring diagram in it
http://www.carlsalter.com/suzuki-service-manuals.asp
Sorry, ill make sure to be more specific next time, and thanks.
The Bike im working on is a 1979 gs750, and i have a digram for it, im just having trouble understanding it. Im aware that the bullet connectors in the lamp are for the lights, but there is also two plugs in there, and these all go into the cluster. what im unsure of, is if i take the cluster off what can i do with these plugs. I can't seem to find if the charging/ignition circuits go into the headlight at all, and once again im having trouble understanding the digram enough wether or not they do.
I suppose ill do what was said earlier and just label every wire, get real close to the digram, and a lot of trial and error.
Thanks for the responses and trying to understand my ignorant question.
As far as reading the diagram there's a bit of a learning curve.
The biggest trick to it is that when two lines cross It doesn't mean anything. Only if there is a little dot or a split does it mean something. So if one like crosses another without a dot just keep following the line and ignore the cross.
Presuming nobody before you has hacked up the wiring harness, you'll be able to trace all the wires to and from your instruments as shown on the diagram.
You can pick up a set of bendable tabs, with two "1", two "2" tabs and so on, to label things as you take them apart; that helped me a great deal the first time. You could mark up a copy of the diagram to match.
Ok, well when i dug in i started understanding it a bit better. I did find thought that the PO messed with somewires, mainly with the turns/brake light.
I am however, having trouble finding some of these.
This plug goes into the tach, i know the yellow/blue wire is the fuel gauge, but am unsure of the others.
The yellow/green is the clutch switch, but goes back to the tail, any ideas?
Finally, i understand that with the idiot lights i want to keep, that when i put a different light it, it will complete the circuit, but what about the lights i don't want to keep? How do i bypass the light, or can i leave them open? Im going to spend more time with the wires, but these are just my initial thoughts.
Re: Re: Making a dash/ taking original cluster off?
yeah, that's not normal. :)
Where does that green wire terminate? And not sure what you mean by "clutch switch"; your clutch lever should not have a wire.
You can cap them off so that they do not inadvertently ground out; you could also remove them entirely. (I would suggest leaving that for last.) :)
Ill probably just cap them off ;D
As for the clutch switch, it shows one going to the start switch, and one wire going to the starter motor. Heres the digram, that will probably be more help. But the the brown wire the guy used is going back to a different brake light.
http://members.dslextreme.com/users/storagecliff/images/750e-s-z_wiring.jpg
ok, just one more thing. There is an orange wire that looks to go back to the first fuse and it goes to my high beam and oil light in the cluster. Is this the power and the other wire the ground or are they both power and the other wire is switched?
