It's probably going to end up just like that with a can on both sides.
man I wish I could afford $2~3k for laced wheels.
Wheels are my current plight. After a bunch of measuring I sorted out that the WIDEST I can go on the back is a 160mm tire on a 17x4.5 wheel. My plan was to go with a 17x5.5 and a 180 because I really like the feel of a 120/180 combination, but doing that will require a custom drive shaft and I will be very tight on room. Can be done, don't know if it's worth the expense. So I went with a 4.5" wheel...I use to race on a 120/160 combo and it felt good enough so why not.
I ordered up an FZ6 rear wheel since I couldn't realistically make my YZF-R6 wheel work. That way the spokes will match and since it's a smaller rim surely it'll be a small hub and wheel and be a little easier to adapt...
NOPE
The FZ6 hub is significantly larger than the R6 hub. It's 19.5cm wide vs the R6's 17cm the OD on the drive side is way bigger and the center bore is also bigger than the R6. The only thing that's not bigger than the R6 is the cush cavity...it's shallower and the hub is hollow so I can't even mill the thing down. Had this rim been on the R6 hub it would have worked passably.
For kicks, though...even though I don't like the idea because the wheels are a little on the heavy side...I went out and grabbed my GT650R rear wheel since it's 17x4.5...just to see. The hub is tiny. I would not have any trouble getting it spaced. I may go that route...run the GTR wheel backward, have the drive side milled and maybe have a flange made and welded to it to mount the spline ring on.
Doesn't look that bad with the R6 front...
