Maritime's new GL - 2UP Distance eater
Something is wonky. When I add 1 incandecent the headlight flashes and Ive not changed anything from previous
Must be the guys at the parts store made a mistake and gave you the special Police Car Flasher.
Lol only I grabbed it off the rack in the store. It says full LED electronic flasher and wires right in place of the one that crapped but just ligbts the led solid and if you throw an incandecent light at it everything in the harness flashes headlight, tail light soeedo lights etc.
38 F today but rode it to work anyway. A bit chilly but 20 mins and took it a little slower. Ran great for the first bit, then I hit a big pothole and a pipe came lose. Fix that easy, I knew one needed a shim under the clamp to seal 100%. Then I looked down to check charging and my needle was pinned above 16V so I may have lost my RR? I had to keep going to get to work but I'll check things out when I get home tonight. I may end up needing a new battery. Now I didn't re-mount my LED aux lights yet as I left the crash bars off and I could have put those on to take some of the charge and protect the battery.
check that the sensing wire (black) has a good connection or hook it directly to battery positive
I upgraded the seperate Reg and Rec from the GL1000 to the single RR unit from the GL1100 parts bike.
Check that the headlight is burning. It needs a little load. RR only regulates one phase, I believe. High volts is how I learned mine was out. Kept blowing the fuse because the dimmer switch was shorting.
Headlight is perfect but also LED. I need to use my multi meter and trace some stuff. On a brighter note. Seat from Ridesolo arrived finally.
index.php
index.php
Going to need some slight tweaks to fit perfect but its 90% there
That, my friend, is just right! I saw pix of your Wing in pieces, remembered that big seat up there in the loft, and just had this feeling. I hope it gives you many comfy and sporty miles/klicks!
Me too. I can still put the monstroscity on for touring 2-up but that looks comfy for solo tours and all the other riding so really chuffed! I need to modify back at the hump area for it to sit down where it needs to, I actually like the cover colour and what I think I may do is fix the hump area, smooth the glass and then re-use the good part of the cover to make a seat pad and paint out the glass to match the tank etc. in the blue and silver. The seat is light enough I should be able to do a smooth coat of glass over and then slight bondo coat without adding too much weight. I am going to have to pull, fix and paint the fender too as you can see the old orange part from the GL1100 parts bike with this seat.
And you can see how dirty the bike got on our roads, that's just from a little bit of water hear and there from snow melt.
This is where the seat hits the frame a little. Not sure yet what to do to mod it. will study it a bit. I have lots of leftover glass and epoxy from the camper repair.
index.php
So the new Napa flasher almost worked. with just LED's the load was not quite enough and they flashed Bright/Dim instead of on off like brake lights. So I added my test light in the circuit and then they blinked on and off. So I hacked the giant incandescent ones and took the bulbs and sockets and wired them in under the false tank and now they work perfect. I'll get pics of the seat progress up shortly.
A few beers and a coping saw and we have the seat sitting correctly. I have glass cloth and epoxy and will glass over the seat to smooth it out and fix the trimmed bits and fill the rivet holes. If it comes out smooth enough I plan to paint it then glass a seat pad pan and cover with the old seat vinyl as I like the pattern and the colour and the only damage is mainly on the hump area I won't need.
index.php
index.php
index.php
index.php
thanks, Modding a close fit was way easier than making from sctatch LOL I've done that once and it was a lot of work and it was just OK when finished, I should be able to get this body worked and smooth and painted to match and it should be an 8/10 or better, I have both the silver and blue paint left over. I can also trim and re-clear the front fender and tank panels as well to freshen the whole bike pretty cheaply.
Going to glass this area and then make a mount here to attach the seat. I'll put rubber under the sides where it sits on the frame rails and use velcro for the pad pan and the it will be a quick one bolt removal and swap when 2-up is needed.
index.php
