marking clubmans for drilling
Ben
i remember reading a tip on how to mark your clubmans for drilling....I cant find that post.
anyone have that tip, something about marking the switches and they leave an impression or something...
thanks.
if you're talking about making for the locating pin/stub, simply place some paint on the nub, and put the switch where you know you want it. To make it easier, when bolted in proper place, use a sharpie to mark just where the switch goes.
that'll get you close enough
heard you can take the pin out of the switch. Need to drill to run the wires on both sides. Dont want to notch the switch gear.
got a tip to marker outline the bar where the switch will go and paint the underside, paint left on bar will reveal roughly where to drill.
will give it a shot tonight.
Here is how I did it. Keep in mind I had the Factory drilled bars to use as a guide
http://dotheton.com/index.php?topic=6825.0
What I do is take some foam mounting tape (has some thickness and is spongy) and wrapped it around the bar roughly where I know where the controls will go. Then i mocked up the controls where I wanted them, and squeezed them around the bar until the pin left an impression. Then I just took my drill and drilled through the impression. Has worked everytime and is simple. You can find this tape pretty much anywhere, grocery stores, art stores, drug stores etc.
