Markings on the side of pistons
Krappy
I have a 71 CL175 K5 and I'm currently doing a top end rebuild. I took the pistons out and noticed that there were some numbers on the side. 313 & 3 and 313 & 4 (on the other one). I am about to purchase some rings and wanted to make sure what size pistons these were. I looked up parts number at Western Hills Honda and it appears that the 313 is a component of the parts number (13104-313-010), but they have this same parts number for all piston sizes.
On a separate note, what do you guys use to remove carbon off the head and valves? I've been using chem dip on the valves and WD40 w/ bristle brush on the head with little improvement.
If you've got the head off, you should consider a valve job, especially considering you're replacing your rings etc.
On the few engines I've rebuilt I've paid to have the valve seats ground, new seals installed etc. and typically have the head bead blasted along with the cylinders.
Are you honing the cylinders yourself?
I was planning on lapping the valves myself, but taking the cylinders in to get them honed.
This is my first rebuild, so I'm finding that my plans change from day to day, so I may consider new stock valves, new rings (once I figure out the size of the pistons) and taking it in to get it all done. We'll see.
