tsquared109
OK, so I bought a 73 Honda cb350 a little while back and I've been working on getting it in running condition. When I finally got around to getting a new battery I realized I had some troubles. I hooked up the battery neg to ground and pos to the solenoid, although I'm not sure which post is the right one to connect to the battery. When I go to turn it on, nothing works at all. No lights, no horn, no spark, nothing. The fuse by the battery is fine but the starting switch assembly is a little broken; I only have the top half with the on/off switch and the headlight control. Could that be the problem? Also down by the key there is a green wire and a grey wire that aren't connected to anything. Other than that all the connections appear fine. Could it be something else like the rectifier or the solenoid? I have no idea how to proceed and I need help.
