master cylinder quesiton
gomotomoto
will any master cylinder (same brand) actuate a caliper? I need to convert a hand lever MC to a foot pedal (rear) MC.
Are you trying to modify a front master to operate a rear brake? I'm a little confused by the question.
Originally, i thought about that (modifying the lever master on the handlebar to work with a rear brake pedal setup that doesn't exist on the bike yet) -- but I'm pretty sure I just want to buy a rear master to operate the rear brake.
the original owner rigged the rear disc to operate from a lever on the bar (no front brake when I purchased it)
Just trying to sort it out correctly now and make the bike safe.
Ahhh... Ok. Well, its going to involve some fabrication. First things first though. You need to get a brake pedal on there. One way or another. After that, yoi can mount up a master cylinder. Anything from a modern bike should work and be relatively inexpensive. Again though, you'll need to have brackets and mounts welded on for all of this. Any pics of the current configuration?
Just to add some info here most modern sportsbike rearsets have the MC mounted on them, so you just have to mount up 2 tabs for the rearsets and the MC and lever will be there.
I bet if he had more time, he would have rigged a front brake too :o
I know, Right ?
Brake pedal/linkage/rod on way (ebay), found the pivot bolt online thanks to someone on this board...
I'll see where everything falls then I'll take some pics before I attack the project. I think I'll be able to fabricate something -- I can TIG steel pretty decent. I wasn't sure if the MC's needed a perfect match for any reason I was overlooking. Guess a general lack of understanding of hydraulics and any subtleties. I'm still relatively new to poking at motorcycles -- thus the really basic moronic questions I'm asking everyone (soooo appreciate the answers/help)
Is that a pic of your setup? Just curious -- to me that seems a good bit of ingenuity, something someone would do out of necessity -- reminds me of the little street side shops in indo -- they make with what they have at hand most of the time.
Ha! No!
found the pic on another forum .. I think it was a " wall of shame " thread for idiotic, dangerous, redneck engineered or just plain stupid mods some of which have been nominated for Darwin awards ;D
I did give it a WTF at first, but try not to open my mouth when I still know less than shit. too funny.
it's total fuckery, but you have to admire someone for doing what they can with what they have & what they know.
DeanJ said:
Ha! No!
I don't particularly see anything "wrong" with it...the workmanship could be a little better. But cable actuated master cyl's do happen. I think i'd use a rear master mounted somewhere out of sight though ahha.
Don't see any reason it wouldn't work.
Looks ghetto, but probably better than having it on the bars ;D
But you still have to have a perch/lever on the bars to actuate it. I don't understand why folks take a simple problem and create a complicated solution. You see it constantly on these old bikes.
If youre building a bike for style, a master cyl is ugly. A perch and cable is much better looking imo.
I can see a bike with no controls, a clutch perch a brake perch, and an internal throttle in my head. Would be badass.
You usually see this with drum brakes (or no front on choppers haha) but if you cable actuated a rear master, say under the tank, you could keep all of the disk brake goodness while having the clean bar look.
Obviously that particular dude failed miserably
I know, Right ?
The biggest problem I have with this set-up is it's putting extra weight into the unsprung mass of the wheel....and that now the MC is subject to all the shocks and bumps the bike will encounter - which will eventually make it fail somewhere along the line....assuming the thing even gets ridden ::)
not as bad a fail exhibit A, yet still silly : http://www.pipeburn.com/home/2012/8/11/bridge-city-cycles-cb-500-unusual-suspect.html
