Feisti said:
Hey man thanks for your replies on my thread as well. I was waiting on getting one of those rubber deadblows today to get my jug off. Worked like a charm
My sears has this valve compressor do you think itll work?
http://www.sears.com/kd-tools-valve-spring-compressor-new-style/p-00999887000P?prdNo=35&blockNo=35&blockType=G35
I have a similar gasket kit to yours, what was your reason for getting the copper gasket made? Did you use any gasket sealer or anything on the other seals when installing them?
Also what did you use to get everything SO clean, your motor looks brand new haha.
I also looked at my valve springs on both the heads that i have and the open ends are all over the place, not sure it matters.
I bought that Craftsman valve spring compressor first, I don't like it for small engines. The spring cup is too big for the 360 head casting.
I think it's more of an automotive compressor.
I wanted the copper gasket to bump up compression, just a little.
It's against my nature to blow apart an engine and NOT give it something over stock.
I didn't use any gasket sealer on the seals, but I did use Threebond to seal the surfaces that don't have gaskets, lower case, valve cover, and on both sides of the copper head gasket, as Lani suggested.
As far how clean my engine is, it soaked in my parts washer for days. First parts went in overnight . . . and I scrubbed them down.
then back into the bath for another day or two . . . and scrubbed them again. The cylinders jugs were glass bead blasted, with the mating surfaces duct taped to prevent damage to the mating surfaces and cylinder walls. they were not original to the bike, so they looked awful at first.
I'm using a degreaser from Harbor Freight called Green Stuff. One gallon mixes with 20 gallons of water. Works well, but I prefer a petroleum base solvent.
The valve springs are a progressive rate spring, both inner and outer. Check out my build thread(link is in my sig), and you can see the difference on page 12 I think.
When I say "open" end I mean that the spring coils are farther apart on that end. So the "open" ends of ALL the valve springs need to be closest to the valve cover.
