Yellow, white, and pink should show no voltage unless the engine is running. Voltage on any of those three with the engine off indicates a bad rectifier.
Ok, YEL and WHT I know are at the engine. PINK? I'm not so sure where that is.
I don't see a WHT from the engine on this diagram, am I correct?
and is the GRN wire at the stator the nuetral switch wire, or a ground needed?
Also... In this picture, most of the wiring colors are wrong for other circuits, so you may want to find another diagram if you need it for something besides the charging circuit.
