Mid range power problem
vtwin650
I finally have a question for you the pros on the site - probably a very easy solution, but figured I would throw it out there.
Got my 74 cb360 road worthy and legal over the weekend and it idles and revs great on the center stand (or whenever in nuetral)
But under power it will bog down at about half throttle in all gears.
Some history - Bike has solid compression, carbs are clean and rebuilt, running air filter pods (I am fairly positive that the carbs have stock jets) new plugs, fuel filters, battery, valve clearances are in spec.
What could cause this situation - it is strange because sitting still with the clutch lever pulled in, the bike will rev all the way up and very smooth - but under power it seems to bog down.
Thanks for the help in advance!
Here is the "Texas Special" as she sits today!
Hmmm. Here's a couple things to check. Points gap and timing, carb float height, jetting adjustment due to the pods (do a search, there are many topics about this). Also I noticed the small inline fuel filters. Those can sometimes get air in the line and cause a kind of "vapor lock". Basically not letting the fuel refill your carbs fast enough. Check those out and double check your other work. If you've got half throttle look on the bright side. You're half way there ;D.
Awesome - Thanks for the advice, this will give me a place to start.
The main thing that confuses me is that it will rev up just fine sitting still.
What fuel filters do you suggest? I did notice a difference in the amount of fuel I could see in each of the clear fuel lines.
This says it all. Running pod filters with stock jets will make the bike so lean that it will barely run. Riding it this way will damage the engine in short order.
You MUST rejet.
Air bubbles in a fuel pipe are normal and don't harm flow but many filters are incapable of flowing enough. In this case, as ADC mentioned, it is probably the pods. Send your carbs to PJ and ask him to wave his magic wand over them.
Well, mr. Honda himself never felt a need for anymore then the filter and screen in the petcock. Try running straight fuel line (no filters) and see how that works. It will at least be a quick step in the deduction process.
Not mysterious at all. It doesn't take any power to rev the engine with no load. Power production is SERIOUSLY down when the bike is that lean. It will rev, but as soon as you put a load on the engine, it will bog down.
You MUST rejet.
How do I figure which jets to install?
Those carbs need different fuel jets and different air jets and they are not available from anyone but PJ AFAIK. The bodies often require modification too.
I don't have direct experience jetting that particular engine, but generally speaking, when you change to pods, you will have to go at least 4 jet sizes larger on the main jet. Might have to go 8 jet sizes. The jet numbers increase in increments of 2.5, therfore, 4 jets sizes larger would be 10 points on the jet number. One size larger on the pilot jet is a good idea, too.
Others on this site can give you more specific jet size recommendations, as they have been there, done that.
I'm runnin shitty pods on my 360 now and I'm at 105 on the secondary main. 110 was way too rich mid range. It barely runs lean at top end and it's a tad rich mid range but it idles and cruises great. I also found some no ethanol gas in town and my bike runs waaaaay better.
