mikuneihins
vandito.cb
does anybody know of any kits or DIYs on converting the need to run a choke cable on keihins (factory VBs from a dohc cb750) to a more mikuni style, carb mounted plunger of sorts?
i've been trying to get as much madness out my front end as possible (my main harness is about as thick as a twix bar now) and also will be doing away with the stock handlebar clamp as i have moved the fuse box elsewhere.
along with that clamp goes the choke mount so i'd like to kill my boss two birds with one stone and mount something on the carb rack itself.
has anyone seen or done this?
You ever find a solution for this? I'm looking to do similar with my CB. Or have you found any other options that work better than the factory setup?
