lbaker
Active Member
Hi guys, I'm hoping not to start a stock vs. Mikuni carb debate, I just would like to clear up some things I've seen mentioned on other threads. My stock carbs are in need of a major cleaning/rebuild, so I was debating just throwing $300 bucks at them for a new set so I can prioritize my time else where. Am I correct in thinking...
-The Mikunis will give slightly higher max speed and MAY have better acceleration.
-The stock carbs are difficult to add pod filters to? Whereas the Mikunis are an easy bolt on?
-Mikunis controlled by actual cables vs. vacuum created by cable movement (is this significant?)
-Keihin carbs slides will still be prone to easy sticking post rebuild?
Thanks for any suggestion or advice you can give....I can take it!
