S T O P . This thread is seriously all over the map. We have 650 twin carbs being recommended and no recognition of the difference in flow between BS(CV) carbs and VM (Slide) carbs.
GT750 Suzuki is fitted with BS40 carbs which have a 40mm outlet, so that's easy. They are 40mm. Right? Wrong. They flow the same as a 32mm VM carb. So 40mm CV = 32mm Slide. That's not a universal conversion factor, just one example to keep in mind.
Back in the day, people did fit some pretty large VM Mikunis to those motors when they were hopped up with big bore kits, ported heads and hot cams. Stock, not so much.
Manas has two price effective options here- assuming his carbs are in good condition. Try to find an airbox on ebay etc of fit K&N pods and jet up a couple of sizes on the main jets to get started. Cheap pods will not work and even UNI filters may have to be modified to clear the ports. K&N are usually pretty good though - but check them.
If teh crabs are all worn out and damaged, that's another story. In that case get a set of Mk2s which are very different and fit pods.
