Mikuni CV carburettor question (technical)
boingk
Standard gearhead.
Righteo, this is aimed more at the technical gurus out there.
I'm working on my GSX-1100 at the moment, having just fitted pods & rejetted to suit. I'm almost where I want to be, just need to raise the needles one spot. The thing is, they're irritating to get out and a bloody nightmare to put back! A needle on a spring, under a retainer guide with a circlip??? WTF!?
If there is a purpose for this setup, can someone please explain it to me? I would really like to know so I can preserve what is left of my mind.
Cheers - boingk
Needle needs to 'float' to center itself in needle jet
No easy way to do it, even with good quality circlip pliers.
Holding onto needle and pulling it down while supporting slide on base of thumb makes things a little easier
No worris PJ, just wanted to know why the the setup was that way. I've previously worked on Mikuni CV's and Dellorto stroker carbs, and the 'orto had a setup that was crazily easy to adjust. I know why they've got the reputation they do now ::)
I managed to get two of the four CV's for my GSX done last night, was up in the shed for about an hour I guess. Worst part was the corroded original screws, closely followed by the irritating needle setup :D
Cheers PJ - boingk
