freedomgli
So I'm double checking everything on my new THR tuned Mikuni VM30 carbs before I put gas through them for the first time and I notice the floats are not set to the right measurement. My Mikuni Tuning Manual says 22-24mm (as measured from the gasket surface to the bottom of the float) but these were like 30mm+ and look as though they haven't been touched as the tang on the float arm that presses against the needle valve is flat and even with the rest of the float arm.
Getting the right measurement is a challenge as my carbs have twin independent floats that ride on brass slides pressed into the float bowl so when I invert the carb and pull the float bowl off the floats have no support as they're not actually attached to the float arm. I fiddled around with some wire in an attempt to hold the floats in place sans float bowl but it was no use so I decided to take my measurement directly from the float arm and add 9mm to it. I measured the floats and they're 37mm tall and the pin that acts on the float arm is 9mm from the bottom of the float. I figure I'll attach a hose to the fuel inlet and blow through it so I know exactly when the needle valve is open or closed. Is this sound reasoning?
But others have said that adjusting the float level is a poor method for setting up carbs and that I should use a liquid column manometer to measure the actual fuel level in the float bowl. I've read some very generic advice that the fuel level should be 3mm below the gasket surface but I can't actually find an official spec for my carbs.
Others still have said that the float arm should be parallel with the gasket surface when the needle valve is closed.
Which method is best? Any tips on adjusting the float height with the twin independent floats? I found this float gauge on a Kawasaki Triple website but it doesn't have provisions for twin independent floats. Thanks for your help! I'm new to carbs.
