I have a new set of Mikuni VM30 carbs that I placed on a cb360. Once they were installed the bike fired right up and idled well, however, it will only throttle to about 5k rpms. I took off the carbs to look at them and noticed that the needle jet rises with the needle as the throttle pulls. I would assume that this might be causing the problem because the needle isn't fully raising from the jet. With this said, I can't figure out how to keep it down.
Does this seem right and does anybody know a fix? Could something else be causing this if its normal? Thanks.
