cxman said:if you have the spring then the washer then the oring on the jet how the !@#$%^ is it backing out
xb33bsa said:or double-up on the o-rings ?
hillsy said:BTW - if you have it all correct and they still back out (for whatever reason), a smear of silicon over the screw heads should stop them moving. That way you can remove the silicon later on and re-adjust the mixture.
