Mono conversions.
Basement rat
Over 1,000 Posts
Same idea as the small displacement rides. I think there are allot of important questions to be asked in regards to this conversion and this would make it easier to look for the answers.
Here are the ones I know of:
Eileen by Twistedwheelz: http://dotheton.com/index.php?topic=12770.0
Gretta by Kanticoy: http://dotheton.com/index.php?topic=10530.0
Thompsonmx: http://dotheton.com/index.php?topic=11738.0
Squirlys 1970 H1: http://dotheton.com/index.php?topic=10971.0
Newmans DOHC: http://dotheton.com/index.php?topic=1521.0
Whitexk TX/ XS 650: http://dotheton.com/index.php?topic=11990.0
Tobiism KZ 750: http://dotheton.com/index.php?topic=3157.0
Eurotrash XS 650: http://dotheton.com/index.php?topic=2008.0
Lastly, mine: http://dotheton.com/index.php?topic=12451.0
More I hope.
You missed both of mine.
First one is XS860, second is my XS800, both using Suzuki Katana 600 swingarm/shock/linkage.
860 is Cafe, 800 is 'bobber', (of sorts)
http://i91.photobucket.com/albums/k315/1crazypj/XS650/XS800-1.jpg
should have posted pic not link.
There's some distortion in picture, its not as long as it looks (4" on swing arm but it looks like 10" :
http://dotheton.com/index.php?topic=11922.0
this is main link for work I'm doing on Yamaha's, I've got 3 XS'650'
http://xs650temp.proboards.com/index.cgi?board=project&action=display&thread=5016
PJ
Those are some nice bikes. Mine is a little less of a conversion as mine started out as a mono. But I will do my best to answer any questions. And it is some sweet company up there.
I am pretty sure this is just a collection of mono-shock designs. I am guessing he would like others to contribute. Something to get the imagination going, and maybe see ideas not thought of by yourself.
I think I'm doing good right now, for what I need in the tech department just anyone else. The idea of this was to get all the DTT Mono builds in one organized spot just like the "mini cafes" not to just pictures of cool mono bikes from the net (i suppose they can be useful too). I suppose any thread be it from DTT or what have you would be fine. I know of a few good ones on the the CB1100F site thanks to Newman I think I will try to search out again for here.
Do you guys think it worth it to ask to have a mono section in the tech section beside Brakes, seats/ tanks, etc?
I think a section on mono-shocks would be a little limited but a section on suspension such as forks and shocks could be useful. That is my opinion anyway.
+2....
im curious how you guys worked out the swingarm mount for the shock... im thinking just measure twice and weld the mounts and your good to go?
Here's a similar thread over at kzrider.com...
http://kzrider.com/index.php?option=com_kunena&Itemid=116&func=view&catid=5&id=346812
These are some I've collected. The BMW is perhaps my fav! But the Duc Bobber is kinda sweet... I'm thinking I'll need to tackle one on the next bike!
The Jesse James Cafe Honda!
Concept Buell
Ducati Bobber!
PA Vern Ducati
Tony Foale CB750
No! No! You need to look into suspension theory! There is tons of information about how a spring & damper reacts to a stimulus under load mounted in various configurations! You need to understand things like progressive design, “degressive” design, rising rate, falling rate, pivot arc travel, load rates, and leverage action multiplying. Not to mention designing your specific suspension to handle the load of a new design. For example, if you were to just weld a bracket onto the flat area in front of the rear wheel on the swing arm, and a bracket a the bottom of the backbone to mount your mono, the frist bump you hit you would likely bottom out the shock then snap your swing arm in half! Then take a ride in a meat waggon to remove pea gravel from your ass! And I am guessing you won't be taking home some hot little nurse unless you're Swagger! :D
Mine is rather non-conventional. I simply replaced the stock dual setup with a single on one side from and R1. There is no shock on the LH side now, so that it looks like a floating swing arm. Since this is on an Xs1100, the swing arm is stout enough (since it is also a shaftie, and the shaft runs inside the swing arm) that I have not noticed any ill effect in cornering or otherwise. I have quite a few miles on this setup. The R1 spring rate is a little stiff, but for handling, this works out. I also have the advantages of the modern shock.My brother is a mechanical engineer, and we have reviewed the entire setup, and he doe not really see any problems with it. Mouniting is essentially stock, so the geometry works well. It looks and performs quite a bit better over the stock ones, so I rock it!
Sorry about the redundant pictures from the Show and Shine link... ::)
