Motogadget M-button with Posh switch? updated
telkinsjr
Hello. First post and all.
I am in the process of doing a rest-mod on my 73 CB450. It's my first rebuild and I have learned a lot doing all my own body work, paint and electrical. I may have had to repaint an few things, and buy a new set of bars after grabbing the wrong drill bit, but it has been a blast and I can't wait to ride and show it off.
Here's my question: I have the Motogadget system in place, along with the M-Button. Everything works great and there were virtually no problems thanks to countless hours searching this forum. Except one thing.
I have the POSH mini horn/turn signal switch installed. When I flip the switch left or right turn signals come on as they should. BUT, when I flip it back to the off position it does nothing. I then have to flip it "on" a second time in order to get it to turn off.
Thinking it through, the M-button is looking for a second "on" signal to turn the indicator off, not a "off" signal from the switch. Has anyone dealt with this before and have any ideas?
EDIT: I have this issue sorted. But now when I turn the ignition off the turn signal indicators flash. But not all the time."
Here's the switch mounted:
Thanks
Sounds like it could be a configuration issue with the m-unit.
Generally, the m-unit uses low-side switching to activate a circuit. This means the switch should be completing a connection to ground for both the left and the right sides.
