Motor de aeration KZ 400
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
hey guys!
after getting single pods for my kz400 i was wondering what to do with the de aeration of the motor (on top right between the two cylinders)...normally theres a hose connected to the oringinal air box(which we removed).
should i put a little 15mm filter on that sucker?
That will work, although will make a bit of an oil spray mess around it as the crankcase "breathes". I have routed mine towards the rear of the bike with a hose and small breather filter, but still makes a bit of mess. Ideally, you would want to install a "catch can" set up.
Gases come out of the breather, not in...Filter will get wet, create a little crankcase pressure....That can cause oil leaks. Probably best just to run a hose to the underside of the bike and let it breather freely.
