dif·fer·en·tial
ˌdifəˈren(t)SH(ə)l/
Gentlemen.
I turn my head for one second and there's a bunch of great ideas all posted up! HA ha brilliant. Every single comment posted was helpful.
Spent most of the day mulling over what you guys have suggested, hinted at, and flat out worked out for me!
jpmobius said:
Of course you are not making a dragster, but my money says this will be a problem, not merely a nuisance. You could simply drive only one of the rear wheels which would eliminate the problem, but if you have a notion to make this vehicle more powerful down the road you will again be looking for some form of final drive that drives both wheels. My guess is that, with the size, weight, and Hp you look to be heading toward, the lame sounding one wheel drive would work just great.
jpmobius, your measured approach, and consideration of the big picture stuff here is spot on. The one wheel drive scenario will be my back up plan.
It alleviated some of my "panic"
... I've been sweat'n a bit on this diff issue.
jpmobius said:
Making the best trade offs often results in what turns out to be the best engineering.
Beautifully put.
My brain block was the shaft / chain issue, and how to marry a [chain / sprocket system] with a [shaft system].
Did a bit of basic research on how a diff actually works. Whoever invented that thing is a genius. Truly.
Here's a great little vid that explains how it works, if you're interested.
https://www.youtube.com/watch?v=SOgoejxzF8c
I guess these components are called different things, depending on what side of the pond you're on, but this is a good illustartion.
- Dont need the pinion drive
- Dont need the ring gear, that .... can be changed out for a rear sprocket
- Fabricate a rotating cage out of a piece of billet
- Let the rotating cage ride on a bearing on the left axle
- Rear sprocket bolted to the rotating cage
Heres a loose mockup to show the idea:
A - BEARING
B - ROTATING CAGE
(arms wont be that long, just to make it more visible for demo purpose)
C - REAR SPROCKET
D - LARGE / SIDE GEAR
E - SMALL GEAR
F - LEFT AXLE
G- RIGHT AXLE
And a couple of pics in situ.
So I need the 4 gears. Need to research the donor. HUH?
