livesintrees
81 Suzuki GS450T
So I have spent the better part of a week replacing the gaskets and exhaust on my Gs450. After I was finished I placed the motor back into the frame reassembled it no problem, then attached all the connective wires and tried to start it up. At first the solenoid just made a tick noise so I assumed my battery was low on charge as I was using it to check my new headlight. After a quick charge I placed the battery back into the bike and gave it a go. This time sparks shot from my positive terminal and the starter solenoid made a fast ticking and whirling noise. Now all I get is ticks. I've checked all my wiring for good connections to both the block and the battery. This bike is an electronics nightmare. The rear turn signals were assembled by an electrical engineer for a school project so there is a lot of bare wires, and solder points.
The spark coming from the battery was like a short or a bad connection so Ive checked to make sure it made solid contact. It should be a straight shoot from the battery to the solenoid to the starter with a ground connection to the frame correct? What could be causing the bike not to start? Im new to bikes, and this is my first project on two wheels. Any help would be appreciated!
Thanks!
Thanks!
