Ncstatecamp
What would you guys say the best way to mount one of these eBay lights be?
Big Rich said:What are you doing for a seat?
jsharpphoto said:i'm mounting (essentially) that same light on my rear hoop. I'm going to separate the light from the plate bracket, and make a small L bracket to mount the light to the underside of the seat hoop. Then i'm going to locate the license plate down on the axle with a separate bracket.
For safety, you want your tail light as close to drivers' eye level as possible, but I think a license plate under the seat hoop looks a bit silly.
My personal preferences, obviously.
teazer said:Just weld two tabs onto the rear loop and you're done.
pawn said:do tabs on the hoop like stated above, or run a shortie fender and mount the light/plate to that. If you don't like the look of a fender you can make it short enough so that the license plate covers it entirely and it's sole purpose is to just hold the plate and light without taking away from your aesthetic goal...plus you get some debris protection by running a fender.
jsharpphoto said:in the custom world, you'll learn to fabricate and dry fit EVERYTHING first, then send off for paint and powder. I learned that on the last build I did. It's rough.
