XsjadoTwin
Hey guys, so ive been finally able to switch my work schedule and actually have time to work on my bike. So ive been making quick progress. I came up with probably not the simplest of ways to mount a seat. But with what ive got it worked out. I took the fiberglass seat and used it to make a template for my steel pan. Plasma cut my pan, then ground it down to fit the width of my frame. Removed the rear hoop, bent the last 3in" of the frame in to fit under the cowl. Welded in a rear support/mounting brace... Tapped holes through the existing cross brace and my welded brace. Welded 4 bolts to the bottom of my pan, slipped them through the 4 holes in the front and rear cross brace and tightened everything up with some locknuts and washers
Here is the final product. Mounting a DCC "Speedster" seat on a 1975 cl360. (Still deciding on paint scheme though, suggestions are welcome)
