my 1971 CB750 project...
Description: 1971 Honda CB 750 K1
MECHANICALS:
836 Big bore kiton an in-line four, four-stroke, OHC
Web Cam
Dyna S ignition
Accel Coils
Heavy duty valve springs
Ported and polished head
1975 GL1000 Speedo Drive
Oil Cooler Ahrma Lockhart
SUSPENSION:
Front brakes: Modified to 1975 GL1000 Dual Disc
Rear brakes: Expanding brake
Front Forks: Modified to 1975 GL1000 37mm forks
CB900f rear shocks
ELECTRICAL:
7" Chrome Classic British Style Headlight Assembly
Trail Tech Vapor digital gauge
Cigarette lighter/charger
Wood Kraft Clip-ons
LED front bar end directionals
LED rear frame end directionals
LED rear taillight
1979 CB750 fuse box
1980 CB750 wire harness
1980 CB900 clutch perch
19870CB900 throttle controls
1980 CB750 left bar controls
rectifier regulator
LiFe battery
BODY:
Frame cleared of all clips and tabs
Shaved down aluminum tripple tree
Custom fiberglass rear cowl
1981 CB750 extended swing-arm
Vance and Hines exhaust
Tires: Shinko 777 Whitewall Tires. Rear:130-90H-16 / Front: 100-90-19 57H
Fuel capacity: Modified to CR Tank = 22.00 liters 5.81179 gallons
Custom oil tank between the frame rails
Weight incl. oil, gas, etc: 500.1 pounds
Beautiful job! That bike is very gorgeous and sounds amazing! I just started a CB500F K2 project and I can only hope mine is as nice as yours when completed.
Thanks for the kind words. I love the bike but still some work to be done asthetically to get her to show quality... its always a work in progress I guess.
I'll be looking forward to seeing pics of yours too!
Thanks for linking to this build from CR. I enjoyed watching the build from the beginning, and I'm looking forward to your blog updates.
BTW, your sig translation is much cooler than mine. My NIV says "...he drives like a madman."
And thank all of you for your comments and support. The rig is back in Cali in relatively one piece. Gonna get her patched up, add a few bits and get her cleaned up for paint for shows and just tooling around on Sundays :)
Some of the things I have already added:
running/floor boards
fork brace
A few things more to add:
steering dampener
cafe flyscreen
bar clip on mirrors
replacement engine cover on the left side where it was ground away by the road :(
...and down.
