drewrc2003
Active Member
Check out my brass kick starter I just made
Basement rat said:why don't you run a die along the kick start lever after cutting the mushroomed end off and use a corresponding tap for the brass piece?
From my experience with those kick levers, the material (cast iron/steel of some sort I believe) is very hard on bits and dies...set screw idea might be the most simple solution, as long as they grip tight...+2 on the loctite. Nice work...should look killer.Basement rat said:why don't you run a die along the kick start lever after cutting the mushroomed end off and use a corresponding tap for the brass piece?
