My CM400 has issues
Jamil20
Not sure what's up with this thing.
The electrical system was working. Now it's not. The bike runs fine after starting, but I have no lights, no horn, and no electric start. Here's what I did:
Hooked up the battery to the multimeter and it's reading 13volts, and I noticed it bubbling with the engine running.
Fuses all looked good. Tried a different main fuse and still no change.
I figure my alternator is working since the bike can idle. I don't know if a broken regulator/rectifier can cut your power. I thought the lights could at least run off the battery, but they don't.
Checked my wiring and it looks okay, a little beat up, but okay. I'm trying to look at a wiring diagram, but I get lost in the regulator/rectifier area. A little help with this would be much appreciated.
Nothing?
Can someone at least tell me how power gets from the alternator to the brake liight?
is it alternator->rectifier->regulator->battery->brake light?
Or
alternator->rectifier->regulator->brake light->battery?
A boiling battery indicates my battery is getting power from the alternator, no?
Sounds like your regulator might be shot... if you're boiling the battery you may be charging with too much juice, which indicates the reg. is bad to me.
May have over cooked some other electrical bits as well, which could explain the lights... what is the charging voltage at idle and at 4000 rpm?
Also... have the battery load tested. It may be no good...
The battery is a month old, I don't think it's bad.
At idle, I'm getting 18volts at the battery. :o
It does sound like the regulator is shot, but what could have been cooked that killed the lights?
Also, what can I use as a replacement regulator/rectifier? Do I need to get an OEM unit, or can a generic unit suffice? Is there a standard for the wiring/harnesses on these things?
Don't know if you have a one piece reg/rect for that bike or not... some are 2 separate items, others are combined. OEM replacement is fine, but you may be able to get one cheaper. Any reg/rect made for a 12 volt bike should work as far as I know, as long as you wire it in correctly.
And yes, if you're at 18V at idle, your regulator is definitely toasted.
Too much voltage can do weird things to electrical components not designed to run that voltage. Could have blown bulbs etc.
Mine is a one piece.
I tested my voltage at the bulbs, and I was getting 0.02. I think my wiring is fried somewhere or possibly within the regulator itself. I'm going to pop a new regulator in, and try it. If nothing, then I'm going to go into headlight bucket. I don't see anything suspicious elsewhere.
There is a great section in the Honda General Service repair manual from repairmanualclub.com that explains how to test the regulator, which wire is which etc.
Try there,
it sounds like a failure to communicate between the internals ciccuits of the regulator.
So I put the new regulator on. Some of my wiring was completely melted, so I ran some new wiring. But...I'm still getting 17volts at the battery.
I couldn't see any problems anywhere else in the wiring, but I couldn't get a good look at most of it, especially in the headlight bucket.
Any other suggestions here? I'm a little lost.
Okay, here's another quesiton.
What's the green wire coming out of the reg/rec for? I got 3 yellows from the alt, red/white from the batt/main switch looks unregulated, black which is ground but the green is a bit of a mystery.
I'm getting 0volts with the bike off and -0.3volts with the bike running. ???
