Oh yeah, the problem I had getting a spark turned out to be my own doing. In my haste I wired the CDI and my temporary ignition/stop switch such that the coil was always grounded. Whoops. Then I realized the resistance chart in the FSM is seemingly transposed, so that if instead of holding the positive probe on the meter to the wires on the row labeled "+" and the negative to the wires under column "-", you do the reverse (positive to "-", negative to "+"), all the readings come out right on the money. Maybe the SANWA sorts it out for you and that's why the manual says you gotta test with one.
Anyway, for $15 I got a backup repop that tests the same as the original Honda and a reminder to slow down on my next wiring job.
