My First Time ;)
GregZ
Hello All,
Thought I'd start recording my steps(so when I break something I'll know why).
I was out looking for a first bike on a budget and a friend of a friend recommended
I take a look at cx500s, and the next week I bought my very first motorcycle.
The motorcycle I was looking at before the CX500 was a Honda CB750, it turned out to be
a complete wreak. However when I was checking up online to see what it'd look like, I found
pictures of cafe racers, and then I got hooked. Furthermore when I saw what the CX500 looked
cafed, I had to make one. Now the brand new owner of a 1980 CX500c, I spend hours searching for
the look I wanted, I'll probably tweak it as I go along, but it's something to aim for.
After spending a few weeks learning to ride, I started looking for parts, and found a 1980 CX500D
for sale as parts...SCORE! That's all for now, hopefully this weekend I'll get around to
stripping the paint of the deluxe gas tank, and fabing the mount for the gas tank. More importantly
Switch over the mufflers(the CX500c has been in the shop for carb and engine troubles), which should
help. More to come soon.
Second day with the new bike(First day it was pouring)
The Good and the Ugly
And finally my inspiration
I stripped most of the paint off the deluxe gas tank, funny story, the tank was blue when I got it with the same trim as the image below but when I started to strip the paint off I found a layer below that matches the picture below(not my bike fyi), which happens to be the same color as my Custom...and even more spooky the Deluxe didn't come with a key, however my Custom's key won't open the helmet lock on the Deluxe, but it did open the gas tank from the Deluxe :blink: .
Also any help for how to clean out the light rust in the Deluxe gas tank would be greatly appreciated! Along with any other steps I'd have to take before it would be ok for fuel. (I've already read the post about mounting a Deluxe tank to a custom)
If anyone can weigh in that would be nice. My custom's rear shocks have two different sized springs(the left one is bigger) but look identical other than that and as far as i know they're oem, the bike was being restore by a shop so they have grab whatever they could find. The longer spring is defiantly the correct on because I can't adjust the preload on the longer spring by hand, but on the shorter spring I can. The deluxe has the same size spring as the longer one so they're correct, is there any way to swap just the springs.(The custom shocks are nicer looking and probably in better condition)
I also got the mufflers off the deluxe, turns out someone had cracked one the mufflers trying to get it out before me, small crack and the crack is "closed" as long as you don't bend the muffler. Open to ideas on how to fix it, the only thing I can think of is mig weld it shut. On the topic of mufflers, does anyone know why when you pull the muffler out only the right muffler has a lead "gasket" on it(the left side has one it just stays in the H box), I thought it was an accident til it happen on both the Custom and Deluxe. Or is it just really coincidental?
I'd really like to use the mufflers on the Deluxe because someone punched out the baffles on the customs mufflers and the mechanic said the bike wouldn't run as well without the baffles(which I some what confirmed when I briefly tested the deluxe mufflers on the custom, just turn on, not ridden), and while the distance between the front of the muffler and the bracket are the same, the deluxe has a flange more forward on the muffler stopping it from going in all the way on the custom, the hole for the bracket is only 1/2 inch off. Has someone else had this problem? or should I just drill another hole in the deluxe muffler bracket.
The skinny section that goes into the H box is shorter on these dexlue mufflers
And shorter on this Custom mufflers(hard to tell from the picture)
(I'm calling them Deluxe and Custom mufflers because that's what they are on my bikes)
Just a test fit, but I can see it shaping up. :)
Does anyone know how hard it would be to take those Honda emblem mounts off the side of the tank and fill them in?
