my headlight sucks
Bmpaul02
the factory headlight on my bike puts out just enough light to see at night but i want more i want light output comparable to a car headlight. Any suggestions?
Get an h4 halogen conversion kit...
I dont know what bike you are on but if you dont have an on/off headlight switch, Id recommend that you put it on when you run this conversion kit....
sorry i always forget to include that... i have a 77 cb750k so no all i have is a high low switch
where do i purchase this kit and how do i go about the on off switch is there one made or should i just buy an off the shelf togle switch
thanks,
brandon m paul
thanks,
brandon m paul
I found this: http://www.indysuperbike.com/customer/product.php?productid=122465, I'm assuming that's what Leon was talking about
The cheap way to do this is to just get hold of a halogen headlight reflector that will fit your bike. I bought one from a wrecked bike with the same size (7") headlight.. my bike is a 1976 CB500T, and the donor was a 1980's GL1100 or CX500 or something. It cost me 15 USD, including the bulb. I think even new, a replacement reflector (just slips in to replace the sealed beam unit, with a hole and clips at the back to hold a halogen (H4) bulb) costs something like 25 USD.
I also upgraded my pigtail to one with a ceramic socket to handle any extra heat from the better bulb (and mine was pretty crappy and brittle anyway), and am running LED lights all around to help ease the pain of the extra wattage to my antiquated charging system.
I hope this helps, and good luck!
i dont know if that would work as hids generally require projection lenses that most modern bikes have
any idea where to get one easily
Hey,
If you have a motorcycle wrecker/salvage yard, that would probably be the cheapest place to get one and recycle it. The west coast has a bunch. I've also seen new reflectors for sale at motorcycle and/or autoparts stores -- I don't see why a car one would not be an improvement over the sealed beam, as long as the pattern is not too crazy. BikeBandit seems to sell units (check under the aftermarket>lighting>headlights section), but they want about 50 bucks for them (including bulb). Doing a Google search for things like "Emgo headlight" or the like brought up tons of stores selling bits that would work for various prices too. Happy hunting!
CheapBastard said:
Hey,
thanks one more wuestion once i buy said light can i just plug it up, also do i need an on/of switch what else will i need?
i've found the biggest power draw is the headlight, especially if you use the E start. with an H4 you're pulling more volts than the stock head light on an already antique system. So just insert a toggle switch in the curcuit that provides power to the hi/low dipper switch or you could just put it on the ground wire in the back of the head light plug to interrupt that curcuit. Then just turn the headlight on after you've started the bike.
Terry
J'ville, Fl.
My headlight harness hooked right into an H4 bulb without modification. You should be able to tell: an H4 socket looks like: |_| (upside down). If not, it's an easy re-wire (as I said before, I did it anyway because my harness was close to fried), as there are only three wires (ground, power to low beam, and power to high beam). Took me ten minutes to get everything hooked up, notwithstanding the annoying little allen-head rusty screw that was holding my old sealed beam unit in the ring...
http://cgi.ebay.com/ebaymotors/7-H4-MOTORCYCLE-HEADLIGHT-HARLEY-HONDA-YAMAHA-KAWASAKI_W0QQcmdZViewItemQQcategoryZ35621QQihZ017QQitemZ270338210065QQrdZ1QQsspagenameZWDVW
55/60 watt direct replacement for my Suzuki gs850. I will have pix soon, but it's a much whiter light than the stock sealed beam, and much tighter beam pattern. I have no data to offer as to whether or not it's better at night yet, but I'll let you know as soon as I'm riding in the dark. Weather will need to improve a bit for that here in central Ohio. ;)
That seller was great to deal with also.
loudest143
sweet but is it a glass lense or plastic
loudest143
