bobjohnson
Coast to Coast
Ok so the last thing i had to do with my cb450 before its street ready was dial in the carbs. I had them off and cleaned them all up, nice and shiny. Both pistons drop at the same time when the carbs are off the bike, they arent sticking and not getting hung up on anything. After i put them back on the bike, i spent about an hour trying to dial them in with both cylinders running, finally got frustrated and decided to do one cylinder at a time. This worked ok, RPMs were the same no matter which cylinder was running, pilot screws were set around 1 1/4 turns out on both sides, and with both cylinders running perfect 1100 rpm idle. Let it run for another 10 minutes, no surging, no faltering, no problem.
Started it up this morning, starts up first kick, settles into a nice idle, again, no surging, no faltering, exhaust pressure is even. I take it out on the road and after about 5 minutes, bam, it starts surging again ??? The idle settles down to around 2k then drops, and gets shaky, if i rev it, itll settle at 2k again, and do the same thing. I cannot for the life of me figure out why.
Im basically at the point where i feel like i have 2 options here:
1) Take it somewhere and have them dial in the carbs. I dont want to do this because its kind of like failing, plus it costs money.
2) Buy some sweet mikuni slide carbs from DCC. That way, i have slide carbs, which is a big bonus (ive only ever worked with slide carbs before and i like them a lot), AND they have a vacuum port so i can use my manometer to dial them in. But again, this costs money, so itll probably be 3 or 4 weeks before i afford to get them. I want to ride now ;D
So, before i go out and drop cash out of frustration, anyone have any tips on working with these slide carbs, or any idea why i get a crap idle after running the bike? Im not running the piss out of it or anything, just regular cruising around. Valves have been set, air filters are clean (Its running the uni sock type filters, because the original airbox was toast, jets were upped by the previous owner to compensate, one size, seems to have been enough), spark plugs are good as far as i can tell. Not seeing any evidence of richness or leaness on the plugs, so it leads me to think that somethings wrong with the carbs but i cant for the life of me figure it out.
