zooke581 said:If you decide to send it out for porting let me know. I do that type of work. But tractability is a must for street riding. You don't really want a peaky motor for the street with the stock gearbox. With a peaky motor first gear is so short it becomes pretty much worthless.
johnu said:....................
Looks like it's going to be a bugger of a job cutting the head tube off without causing to much damage to the rest of the frame. I'll remove the stiffener gussets first then go from there.
No jig yet but I will be constructing something. First I will be installing the new swing arm pivot brackets (before removing the headstock), ref points will be headstock, bottom of chassis rails and rear engine mounting point (engine will be in frame bolted to front two mounting points). Once I have the swing arm pivots in place they will then become the ref point for relocating the headstock. This will obviously not be an overnight job. There will be lots of checking and leveling and shimming, aligning and realigning (I am a bit of a perfectionist). I enjoy a challenge!50gary said:Do you have jig or some kind of fixture to help with the alignment? In what order do you plan to do the frame mods? Do you have a reference point once you cut? I agree the T500 frame around the head stock is a mess so to say.
Cheers, 50gary
Teaser, not sure if you have seen my list of mods or not, but I am going to be using kawi 636 forks and yamaha fzr swingarm. Great link you attached, I have seen it before and it certainly emphasizes the effects of the various adjustments that can be made. However I imagine you would have to jack up the rear end substantially to get the rake angle from 29* to 24*. I am in the process of trying to get all the chasssis dimensions so I can create a cad drawing and go through the geometry that way.teazer said:I must have missed something along the way. Why are you planning on such drastic surgery? Raise the rear end, drop the front a little, reduce fork offset and I suspect you will end up with as much rake and trail as you can use.
I'd measure things first and see what you actually need to change. This is one analysis that may help to put things in perspectiive
http://pinkpossum.com/GT750/phattrakka/part4a.htm
