My Suzi T500 Project *It's Alive Video*
Re: My Suzi T500 Project (expansion chambers finished)
Do you mean the big metal flakes of the speed boats and hot rods of the 60's and 70's?
Yep that's what I'm thinking !
Yes that's it exactly. I don't know if you can get that done in powder though.... or if it's going to look lame?
Decided to add a couple of gussets to the top shock mounting just to be on the safe side. Think I am just going to go gloss black with the frame, then "if" I have to ever modify anything it should be easy to match up. Probably do the swing arm silver though.
I used ceramic silver engine paint with a clear coat on my old GS1150ES frame with good results. I also use it on my GT750 and T500 cases.
Frame is in for powder coating . Going with piano black, it is like an ultra gloss!! Only $150, hopefully the quality will be good.
Super work johnu! My GT 750 came out nice with the black frame and big silver metal flake under blue on the panels. You have a sweet build man, can't wait to see it roll'n.
Re: My Suzi T500 Project (The Build Up Begins!)
Here's the frame back from powder. Got a little work to do on the swingarm before paint then the build up will begin!
Do a search for Roth Flake. They sell it in spray cans now, even. I plan to use it on my tins.
Just in case you don't know about Roth, he was a real character.
Not to hijack.
http://www.ratfink.org/ratfink3.htm
Got the swingarm primed today. I won't be powder coating it as it has some kind of foam rubber inside to deal with vibration I imagine. Will be doing s/a in silver to tie in with the silver forks and contrast with the black wheels.
Humm? I never realized there is foam inside of the FZR600 S/A? I have one on my XS650 Yamaha and I powder coated it, mine is a 1994 arm.
Cheers, 50gary
You know what though Gary, the foam rubber probably wouldn't melt at 350f which is what I think they bake the paint at. I am painting oit myself for two reasons actually, first the aforementioned foam and secondly the fact that I could end up changing the colour.
Yep, have you ever tried to remove fresh powder coat, that is not an easy task? You must burn it a with a torch to age the new coating so it becomes brittle then it can be blasted off.
Paint looks better as well, powder is good for what it is but a paint job is still the best finish. Your bike is going to be so nice.
Cheers, 50gary
Swingarm with first coat of silver.
Pipes are finished with all brackets on and welded. I can't believe how light these pipes are!
Everything is just so sexy!!! Those pipes are sick!!
Those pipes are so bloody hot.
That swing arm has a lot of surface to show off the new paint, cool!
Ok got a little more done today, rearsets are on and the triples are painted.
