motoduck
Active Member
Well I figured it was time to start this thread my first 'real' thread. Well I'm finally getting moving on my build after a two year break, I got this bike as a chopper monstrosity extended forks no cross bar for the head steadies and a crappy 70's hard tail Z bars the whole bit.. I spent alittle bit of time trying to make it a tasteful hard tail with intent to get rid of it and was struck down with mechanical issue after issue ( motor seized 3 times .. in 3 different ways!
) So now that I'm keeping it out of spite really it's going all cafe all the way. pretty much starting over from square one, sold off most of the chopper crap it came with to get it out of my garage. And, if all goes well I should have the motor back in the frame by next week. Ok so im going to try and figure out how to post pics.. if I fail it's all documented on my blog http://cafetrumpet.blogspot.com
Edit: Oh yea I should note.. it started out as this:
This is where the frame is now, having to use a T100C frame that I got from one of the local Triumph elders around here.
Though nothing is bolted on the top end, I had just gotten my shinny new cylinders and had to at least make it look like a motor.. it's the little things..
Hard to tell in the photo with the light/flash but those rocker arms are actually pretty shinny, started lightening and polishing em, still haven't found the magical washer combo that will let me pull those stock springs outta there...
And despite a few clean up attempts this is still what my bench looks like .. though some of the names and locations have changed the parts remain the same.
If all goes well I might be getting a Mojave 360 tank for her here soon... we'll see if the owner of said tank can be talked into releasing it...
