My tach is too big!
mysta2
Over 1,000 Posts
DTT BOTM WINNER
69 is going to have gauges... or at least one master gauge. I tore apart my stock one tonight to see how big the mechanism was and if I could package it down significantly. Well it's not very small and I don't know if I can really improve it much:
Also how freely should this thing spin? It's really slow to return to zero. Should it be this gummy?
Will one of Mikes (MikesXS) mini tachs work for my 360?
One of these:
I'll be ripping it apart right away to remake it... ironically bigger, but need to start off with the smallest package possible. Is this a bolt on affair? Or do the Yammers have a different ratio than the Hondas?
I was looking at the gauges at Mikexs as well and I found on another thread here that people on here have used them on their hondas. It was a cb450 I remember because thats what I have.
I did a lot of digging trying to find out if those gauges would work on my kz650 last year. I didn't find a definitive answer but ordered them anyway and they work perfectly on my kz. After I installed them I found a reference somewhere that MOST of the Japanese bikes in the 70's used the same ratio speedo and tachs. That one should do the trick for you. Great gauges too, I have a lot less needle bounce than I did with my 30 year old stock gauges.
Is the tach on your KZ driven off the cam or the crank? Chris just suggested that it may not work for me because of this issue. 360s are driven by the cam.
yeah, if only the sweep of the thing was only 150 degrees rather than 300... I could just print my face to compensate. Or maybe the placement of the magnet might do the job, I need a calibration bench.
Hey sorry to mislead you on the tach. I didn't know it wouldn't work on your bike. I just saw it worked on a 450.
CB450s tach cables run off of the cam like the 350s.  If it works on a 450, should work on a 350.  They use the same tach. I remember the 450 with the gauges from mikesxs. I'll have to look for it.
I think you were thinking of Herm21's rockin ride. It is a 450 and I think those gauges are from mikesxs.
Herm......are they?
Well, one way or another I'll find out, I sent an e mail into Mikes but suspect that it's probably too late and I'll be getting it in the mail shortly. Regardless, Chris has one that I can play with, I'll let you all know how it turns out.
One other thing. These gauges are sealed and cannot be disassembled. I know; I tried to disassemble mine so I could have them powdercoated. This isn't a big deal for Mysta2 because he can just machine up some new cups, but for the rest of us, it might be an issue.
Nevertheless, if the tach works, that is HUGE. I suppose we'll find out this weekend :) I know I'll run it on the CB360.
Finally, I do think the speedo will work just fine.
--Chris
These CB gauges can be disassembled if you are careful. If you slowly pry up the metal band that seals the two halves of the housing together, they will come apart. Then when you put them back together, you fold the metal band back over the lip of the bottom. Smooth, sand and polish the visible edge. Pry the band off from the bottom, after you put it back together, this side will be against the cushion so you won't see any tool marks.
KZ is driven off the cam. Ratio on the tach is 1:5 if that helps anyone.
1:5?
You mean cable:crank right? So if the actual RPM of the crank is 5 the cable (and the magnet inside the tach) is spinning at 1RPM.
Yes, that helps immensely. I needed that to recalibrate the magnet straight. Thanks!
Ok, I've got some definitive research.
I made myself a square drive for my electric drill and compared the old tach to the new one.
9250 : 7000
old : new
Honda : MikesXS
So I'll just re faze the face when I make the new one. It'll only sweep about half the face in reality... but I guess that means I'll have to stick some idiot lights in there too.
