Mystery calipers
stroker crazy
crazy as a fox
Can anyone help by identifying the source of these calipers?
They're made by Sumitomo probably in the 80s. I've got everything to to restore them except for seals for the larger pistons.
The pistons in question measure 33.25mm with the smaller ones (which I have seals for) at 27mm.
I've been able to track down seals for various four-piston Sumitomos with 34/30, 30/27, 32/32, and 32/27 but no 33.25/27.
If no one can help I will have to junk these calipers and start looking afresh.
Crazy
You need to measure bore where piston fits, probably find 34mm seal work fine
Also, what is the mounting bolt spacing?
Various manufacturers use 'stock' sizes
Kawasaki are real 'narrow', Suzuki wider, etc
crazypj - the piston and bore measure about 33.25mm with the verniers; 34s are too big.
I have spoken to a person who is a professional brake caliper restorer and he hasn't come across this particular combination.
The mounting bolt centres are 83mm.
Crazy
I'll check some calipers later, it's almost 5:00 am, need to get some sleep
I've got some YZF750 , Brembo, Tokico and whatever Honda use as sliding calipers.
Garage soon, need another coffee first ;)
I haven't measured too many but here's a partial list
GSXR600 Niisin 30/27 - 4 piston
GSXR750 Nissin 34/30 - 4 piston
GSXR750K1 Tokico 34/30 - 4 piston
SV650 Tokico 30/30 sliding
RS125 Nissin 34/30 sliding
CBR600 Nissiin 25/25 sliding
96TZ250 Brembo 34/30 - 4 piston
Nothing close to 33.25/27 so far
Thanks teazer - I might just have give up on these calipers and get something that will suit seals that can be found.
Crazy
I measured some of mine, Katana was closest mounting at 85mm, didn't get into piston sizes, too busy doing yard work :(
It's definitely 83mm crazypj - seems to be a Yamaha thing.
They used that spacing from the second model of the RZ onward, and also on the TZR250 and FZR250, if my memory serves me.
Sorry to distract you from yard work; some 'pleasures' just can't be avoided!
Crazy
Belt broke on mower, ended up doing almost 1/2acre with weed whacker, took all day >:(
It was so damn hot I'd use tank of gas, (liuckily it's only about a pint at a time) get some iced water/cool down, re-fill tank, do it all over until done back and hands hurting like hell tonight.
I guess the steroid injection last Monday helped, didn't end up on my knees more than twice, lost almost 4lbs through sweating (only another 40 to go ;D )
What was the (watercooled RD engine) 250 'supermoto' Yamaha made?
Friend had one, just can't remember the model/name? (or was that the TDR?)
I guess I could just e-mail and ask him ;)
It's probably the TDR you're thinking of.
It came out in '88 and I think the motor was the same as the TZR250. Would have been a fun ride but I don't think it was released in Oz.
Crazy
That may be it, it was only released in limited numbers in UK, (couple of hundred total)
Brian only got one because we were Yamaha dealer
