Did you by chance get a different wheel or hub for the rear during your build? A lot of times those things are still stuck in there. If so you may have an extra.
No its the hub that came on the bike. And I already have the engine spacers installed so it can't go there. The only place I could think it would go would be inside the hub under the drum brake plate.
Thanks for the help everyone. i turned out that I had a different axle spacer where this one was supposed to go. Got them all swapped out and installed and now the spacing is perfect!
