It's a small cylinder plunger switch that fits inside the clutch lever perch. Wires run from it to the wiring harness. It's there to prevent the starter from working if the clutch isn't pulled in.
I need one to convert for brake light use for a drum front brake. Even measurements will suffice, so Noel, get out your ruler that you keep beside your bed and measure away - you might need to find a bigger ruler though
