Need a little disc brake help
vegasvic
So I’ve been “searching” for awhile and I think I have it down. I have a 1975 CB 550F.
If I want front dual disc brakes I need to find a donor with dual disc set-up that has the same shock diameter as mine(see fork tube diameter chart). I need to get the shocks and calipers. And discs themselves?
For the back, if I have drum brakes and I want a disc, I need to get a swing arm that has a disc caliper set-up AND that fits my bike?
Do I also need to find wheels that will accommodate the disc AND has the same axle diameter (also see the chart)? And I can just use spacers if I need to to get the wheel to line up?
If I’m making this too complicated PLEASE let me know because it seems complicated to me. Feel free to tell me where I’m wrong.
Thanks
vic
CB550K3 or F1 (F2)
The holes in hub go all the way through
All you need is a 550 disc, caliper, longer bolts and larger piston master cylinder.
If you can find one, an early speedo drive.
If you have an early model without caliper mount on forks you can fit complete front from late model, CB650, or just about anything with fabrication.
;D
Thanks crazypj!
Well, the plot thickens. I was told my shocks look like air shocks off a silver wing that someone has driven a bolt into where the air valve used to be. Hmmm, maybe I should have looked around a little more for a better project bike? Or not so much of a project...bike?
Anyway, maybe it'll make things easier for me since I'll be looking for different front shocks too and maybe I can find the whole set.
vic
