Thats the problem. Theres no spark on the right cylinder but there is on the left. I thought it was the pick up coils so i replaced the signal generator and I still have the same problem. Tried testing the cdi unit how it suggested in the book and i wasnt getting the results that the book said i needed which is,
-Remove both spark plugs and put them on the cylinder head with plug cap attached.
-Disconnect the signal generator lead wire from the ignitor. Turn the ignition switch on.
-Using a meter set to RX1, test the ignitor unit.
-Connect the + probe to the black wire terminal on the ignitor and the - probe to the yellow, black, and green terminals respectively.
When both probes touch the lead wire terminals, the right spark plug should spark.
So I did all of this and I coudnt get a spark for the right or left side, but when i turn the motor over the left side sparks normally and the right one doesnt do anything. Ive tested the coils and I get the same reading for both. Im stumped, I want my bike back "only source of transport" and im not sure what to do. It seems like ive tried everything. If anyone has any electrical suggestions and/or upgrades, please shout em out!
