need help 1985 xv700 virago
focusinprogress
City Limit Moto:Parts-Service-Apparel (716)8038606
So, I've been trying to help a buddy with this 1985 xv700 he bought for really cheap. When he bought it I was not involved, but he claims he test rode it.....the previous owner had botched up the harness with some random push button switch by the seat as the starter button and however he did it was causing a major draw and would drain the battery, so the previous owner was disconnecting the battery whenever he was done riding.
so I spent some time looking over this handywork, and deemed the harness irreparable. Buddy got on ebay and bought a used 1984 xv700 harness and almost everything plugged right in.....but we then realized the previous owner had SOMEHOW made this thing run without a cdi box.....???WUT. friend buys cdi box. plug it in. connect fresh battery, nothing happens. starter button makes the gauge backlights go out. not sure if this is a power cut feature using a relay like xs650's have the headlight relay that cuts power until it's running.....anyways, I find the male bullet connector thats on the shifter side near the battery box....and hit it with the PowerProbe....wire shows ground, if I apply power the starter cranks.
this is where I get confused. based on the diagram, It appears the solenoid is supposed to be triggered by completing a ground when the button is depressed....so why then does it crank when POWER is applied?
so at this point I start thinking, well if everything else works as it should, I could just wire up a switch to trigger the starter (but make it only work when key is ON).....so I start testing stuff, and another concern is I don't have power at my red/white wires in the harness at any point.....this includes up front where the gauge cluster plugs in, where the starter/kill switch plugs in, where the side stand relay plugs in, where the relay assembly box plugs in, nor where the cdi box plugs in. Which leads me to the question....where is that supposed to derive power from? or rather, where is the begining of the line for red/white where it initially sources power for all those devices?
help? lol.
for referance:
diagram -
"relay assembly"
"sidestand relay"
it seems like I could potentially just setup a relay to apply power to red/white once key is ON, but this is an unmolested harness and in theory should work as is unless I have some failed componant I'm dealing with or something. I wanted to test the starter solenoid, but I cannot get that cover off that hides it right on top of the starter motor up front as the philips screws are already stripped and stuck.
what I need, is something like this diagram for the relay unit. I feel like my issue is going to be in there. if I can't figure it out I'm going to make an auxilary harness that takes keyed power to the cdi and start button and splice that in with new wires from the start button to the solenoid and see if that gets me going.
If there is no power on the red/white wires, the first place to check is the fuse (use a multimeter, don't just eyeball it). From there, the kill switch sends power to the TCI unit and the coils.
The main fuse is good. there are no other fuses per say in the system, just that relay box....I don't have power on either side of the kill switch at red/white.
The fuse box location can differ, but if I recall, yours should be up inside the instrument cluster.
hmm, If it's in there I missed it when I had all the plastic covers off it to paint them black. I'll pop it open and see whats up in there. Would love for this to be a simple issue.
