Tim said:You keep saying head. They bored the cylinders. And you're saying they bored the block itself and put new sleeves in? What is stock size?
If they bored the block and put big bore sleeves in and you don't want to run it as a bigger motor then sell your block and buy a stock sized one and some new pistons.
Or go up a size and use that big block you have.
Tim said:Man I'd leave that engine as is and run it. Its clearly a performance motor. Its going to cost you more to undo all that work. The head may be ported too. If they put a big bore kit and hot cam in they likely ported the head and possible enlarged the valves.
If nothing else I'm sure you could sell the block, cam and head as a set.
What is stock lift and duration for the engine?
Sent from my Nexus 5 using Tapatalk
crazypj said:I would check Wiseco for Honda 200 ATV or XR200 pistons and see how they compare to what you already have 8)
With a performance motor you really don't want to go smaller![]()
