Need help achieving this look
eightsevenzero
http://www.flickr.com/photos/nutterphotog/3805868291/#
I really want My CB400TII to look exactly like that. Unfortunatley that is a CB400TI that has a more rounded tank and he did something ith the stock seat it looks like. I am in the process of trying to find a CB400TI tank and a CM400 wire front rim with drum to match my rear drum wire rim i have. My main question:
what was dont to the front end? it looks raked slightly?... anyone know whats going on there?
also, how can i get that finish on a tank?
thanks
If you want one exactly like that contact the owner and buy it from him. It will be way cheaper than building your own, and there's no chance you'll get it wrong and fail to exactly mimic his tastes in motorcycles.
i hate to tell you but theres hardly any original ideas anymore. ultimatley, someone somewhere has already done it. That being said, that is MY taste in bikes. granted i'll change a few things but that stance and appearance is what I enjoy.
Most likely it hasn't been raked. Probably just lowered the front end a little. That, and the bars and headlight help give it a low slung look.
Can't help with the tank, but are you absolutely sure you need a 450 front drum?
That must be one noisy anti social bike - no mufflers - just short headers. Not a good idea. Wires hanging all over the place is easy to copy. Tank looks like a cheap rattle can with big runs and some dents. Also easy to copy. Side covers thrown away, ditto. Seat- modified for sure.
As you can tell, I think that bikes is sub standard and you can do much better. Assuming that's what you want to do, look at the bike as an overall look and then look at the elements that contribute to that look. Front end is probably not raked. It's probably the angle of the shot plus that fat front tire.
Paint the tank a shade of gray to get that monotone look. Pipes need mufflers of course. There are a few so called Brat styles bikes here you can get ideas from and a couple of 400 builds too.
basically strip the tank and clearcoat it. take everything off that doesn't make it go fast. add clipons. remove the fenders and mufflers.
I think its the way the picture was shot that gives the illusion to the front end.
Yeah figured that angle was contributing a little...
The tank I want to do a shiny bare metal then clear over it so it doesn't rust, how would I achieve that with a stock tank? I'm not too familiar with how to buff a tank to a shine.
You think that front rim is bigger than the back rim? I don't really know what rims are compatible with the cb400TII so any advice there?
I think a good place to start is to launch a project thread with some pics of what you're starting with and inspirational pics of where you want to end up. All of us (no matter what anyone tells you ;)) has been inspired by something we've seen somewhere - the only way to be original is to combine existing ideas in a new way that hasn't been done before.
A motorcycle is two wheels, frame, engine, seat, tank, handlebars and not a lot else. Boil it down to those basics and make each of them what you want and things will come together.
The tank has just been stripped to bare metal, and maybe sprayed with some rattlecan clearcoat from the corner store. Will hold up fine, and any bits of flash rust on the exterior just make it look better. Carry some fine grit sandpaper with you to clean it up every once in while - really! Just make sure the interior is clean.
It's highly unlikely the front end has been raked. 95% of us out here working on these bikes don't have the skills or balls to rake our frames in our garages. It looks raked because all the excess crap like fenders have been removed and the angle of the photo.
The drum brake looks cool, but don't spend a lot of time or money looking for one. Nothing wrong with a disc spoke wheel, and you'll be a lot safer on it. I run a drum on my XS650, but it's a Suzuki 4 leading shoe double sided brake, which is a pricey toy and hard to find. I paid as much for the brake hub as I did for the bike. It stops about as well as my BMW R75's single disc brake, and it's about as good a Japanese drum brake as ever existed.
Start taking stuff off your bike and you'll be amazed at the way it starts to look. The front fender is an important structural element in your suspension though. I removed mine, but run a fork brake to keep the fork lowers moving together properly. The fender has a strong U shaped brace in it that is the mount to the forks. Many guys grind off the rivets holding the fender to the mounting bracket and leave the bracket in place. Spray it black and you'll never notice it, except when you're carving a corner and your bike handles properly.
Start digging in! Make it yours, and take lots of pics along the way.
I really want to do the drum front and rear, love the look. Is it
Common to run a bigger rim in the front or is that also the angle of the pic?
Tank looks like it may have been nickel plated (easy to get done if you work for a plating company)
Seat looks like a slightly modified CM one
That's probably the only angle where it looks good, rear end will look awful from just about any other angle
Front end looks completely stock, except for removing mudguard.
Clutch cable running outside fork leg is going to make turning left pretty 'interesting'
Pretty sure a professional photographer could make any old turd look good, that is not a well put together motorcycle
Tank was stripped for sure- I did it to mine a couple weeks ago. If you use an electric sander be sure to be careful; it's very easy to leave marks all over the tank, which you'll then have to sand out by hand. I haven't clear coated mine yet and it's not rusting. Not recommending that, just saying you can get away with it for a while.
Here is how mine turned out:
Goodluck.
eightsevenzero said:
Were you able to buff out those sanding marks on your tank? I want mine a smooth gloss finish if possible.
I haven't yet, but I will. I tested it using 400 sandpaper to smooth it all in one direction, then went finer to get rid of the lines. But I'm also going for a raw look so the lines kinda add to it. As long as you're careful stripping it you will have no problem. I did mine quick using an air powered sander than was probably too rough.
If you want a really smooth finish, it can be done with finer and finer grades of wet and dry and then use a bench grinder with buffing wheel and buffing compound (not paint buffing). Or get it plated as PJ suggested. Left bare for a more industrial look, a satin finish looks better IMHO and that is all the lines going in the same direction like a kitchen sink.
I'm with ya teazer, I'll be doing the satin finish.
