tommyboah
Active Member
I've finally got my bike ready and it is firing, but running poorly on idle. I need to use the throttle to keep it running. I am trying to figure out a procedure for doing the adjustments, and to be honest I am not sure which end to focus on first.
The engine has been bored to 1075ccm and I've got GPZ1100 cams and new valves. The valves have been shimmed correctly. I have also got new carbs, Mikuni RS36 with K&N filters, along with Dyna-S ignition. Pretty much everything is different from stock
hmy:
I have figured that I should focus on the idle running to begin with and I have these things to address, but I am not sure which order I should do them in. My suggested order is:
- Tune in the Mikuni RS carbs
- Tune the Dyna S ignition
I figured I should tune the carbs first in order to get it to run on idle by doing addressing the following:
- Carb idle mixture screw (pilot jet adjustment) I have found the procedure for this on the Mikuni tuning manual. Find the middle position between 1/2-3 turns on the screw
- Carb idle adjustment screw (how should I adjust this for a default position, and what exactly does it do? Is this just an offset for the idle throttle?)
How do I start adjusting the carbs, as I have to hold the throttle to keep the engine from dying? Do I need to do something with the idle adjustment screw first, before addressing the idle mixture?
Or do I have to do the ignition timing before I do the idle adjustment? Pretty hard to do this alone while having to hold the throttle :blink:
I appreciate any help, as I am pretty new to the art of engine tuning.
Thanks.
Thanks.
