need some short shocks for a 350
Check here and scroll all the way to the bottom. They have 11" eye-to-clevis shocks.
http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
If you can afford it, I believe Progressive makes some 11" shocks that fit.
shocks shmocks... throw on some metal brackets and rigid rear end that thing ;) ;)
all joking aside... check gaybay regularly... something always turns up.
Here's an idea I had about shortening Honda rear shocks. Has anyone ever tried this or heard of anyone doing it?
Disassemble the shock and take the top rod end off of the rod. Cut the rod down to the desired length, rethread the rod and reinstall the rod end. Reassemble.
Of course would add preload to the shock and reduce the travel but any shorter shock is going to reduce travel.
What do you think? Sound feasible?
CC
CC
itll work but they wont handle that well. actually, come to think of it, you COULD cut the stock SPRINGS, weld the edges closed again, and then put it in the shock with the cut rod. Itll work, but if the spring comes loose your kind fucked.
just drop the cash on shorties ;)
uh....ok....so back to my original question....where would that be??!!
Take your pick:
http://www.cyclexchange.net/Accessories%20Page.htm Scroll down a bit
http://www.crc2onlinecatalog.com/Index_Main_Frame.htm Scroll all the way down
http://liquidchopperstore.com/kms-5.html
http://www.tasclassicmotorsports.com/servlet/the-573/11-Inch-Short-Shocks/Detail
http://cgi.ebay.com/ebaymotors/NEW-Shorty-Bobber-11%22-short-shocks-eye-to-clevis-chop-_W0QQitemZ220381708591QQcmdZViewItem
http://www.hvccycle.com/mdischocks.htm
etcetera, etcetera
cabrito said:
thanks!
i guess i went full retard with my search terms...
Never go full-retard!
Seriously though, 11" is about a short as you can go (I don't think there's anything shorter available off the shelf) and keep some useable shock travel. Just make sure they're eye to clevis and 99% of the time you should be good to go.
