Ok folks - fresh start here. I had ended up taking my frame into Cyclewerx for the minor amount of welding I needed done, as they are around the corner from my house and we reassembling my engine for me (cylinders, head and riveting cam chain). After 2 weeks of no movement, I'm looking for a possible alternative.
I know there are some welders here, and spoke with one of you about this but wanted to start fresh and open it up to everyone for suggestions. I'd like to get it done soon if possible, and of course the less expensive the better
I don't have material as unfortunately I was unable to connect with Anne before she headed to Montreal. She was going to do the welding for me originally, and even scored me the material, but alas we didn't connect (my fault).
This is what I need done:
-Two short (4 inches or so) tubes welded between the area near the swingarm pivot bolt and the centre tube of the frame for bracing
-Two 1/8" thick or so plates welded across the seating area - one triangular one near the front of the seat where the tubes converge and meet the top tube of the frame and one rectangular one across the seating area (about 10" across by 3" wide) at the top of the shock mounting area.
-One small plate welded vertically on top of the top tube up near the steering head - this would be a 1" x 1/8" thick plate that I would shape afterwards to bolt the tank mounting strap to.
-Welding up an area down by the centre-stand mounts (where they used to be) - there's a bit of a valley between a plate and the frame tube I'd like to fill to make it flush and to strengthen it - two 3 inch or so long welds should do it.
-Covering / filling in the hole left by me cutting off the fork lock on the steering head tube. Its a 3/8" or so hole that ideally I'd have filled in then I can grind it smooth, or a 'bandaid' metal plate welded over it to keep crud out.
