Need to buy! CB360 screw and float pin
Rpino7
A.T.K.H.
I am in need of this little screw and a float pin.
thanks for all the help in advance!
If no one else comes up with parts I can make them, made float pins for mydlyfcyzis.
They are a somewhat weird size, 0.1065" diameter. The blanking screw is relatively easy
Looks like the little clip on shut off valve is also missing?
crazypj are you talking about the clip that holds the float as seen in this?
Yes ;D
The clip is on shut off valve though so float can 'pull' it down as fuel level drops
Check the rubber tip for wear or damage, it may be quicker, easier and cheaper in the long run to just get repair kit
