Need to reverse starter motor, ideas? SOLVED!
tubeglower
I need to change the spin direction of a starter motor for a special project, the motor comes from a fzr 1000 exup '92 and as any dc motor, it changes direction when changing polarity in the conections, but i cannot go this way direcly since it supposes a complex wiring for the cdi and having the spark plugs "inverted" also in polarity. I intend to have everything in the normal way and change the motor internal conections in order to have a normal negative mass and positive active wire. I wonder if:
- changing the leads in the brushes will be possibe, or
- reassembling the permanent magnet body in the opposite way
Suggestions?
Trying to build a bike with reverse haha?
Re: Need to reverse starter motor, ideas?
I'm a moron when electronics are the topic, but ill pose the question to our electrics guru at work.
Not really... But it could be cool.
I need to adapt this starter motor to a Folan engine (it must be one of the prototypes that tis guy produced, a lot of stuff is "oneoff" mods), if i succeed then i will ser whatt i do with the beast.
Thanks... I will dissassemble the starter motor tomorrow and make some pictures. It shouldn't be so difficult to hack it to spin the other way, i guess :P
You know...
There are some engines which spin in the opposite direction of others. Perhaps a starter motor could be adapted?
VonYinzer said:
You know...
Yes I do. For this case I would need a starter that is in a forward position (most of the starters in inlines are behind the cilynders), there must be options out there, but:
- it happens that the one i have matches very nicely in the assembly, both, geometry and the gear in the shaft are ideal, and i consider this is the most difficult thing, having another starter that spins in the opossite way but having to do a big job in alterations to get it adapted might be even worst... :-\
- i already have it, so if it would be easy to make it spin the other way, i will save some money and i will learn something new in the process
getting it to spin in reverse shouldnt be hard..but getting the gear to kick out when reversed will be the issue
;D ;D ;D ;D
I've done it!!
It s actually quite easy, i describe what i did just in case anybody needs to hack a starter for esoteric reasons.
1. In theory, changing the connections of he brushes we'd get it spin in the opposite direction, i open it to investigate how the connections are actually done, and when it is theoretically easy, in practical terms was not that easy, since i needed to isolate the brush that is connected to the whole body and therefore is the negative, and ground the other one which was the positive. So the first option needed a relevant modification in the brushes chassis, i discarded it as a first option
I went directly to the second idea:
2. In theory, facing the next magnet in respect the brushes pair would do it, to do that i just neded to file a small notch in the magnets body, similar to the existing one, it should be centered with the next magnet, since the magnets are placed in the body in an alternated way (north-south-north-south). This would allow me to actually assembly the body in the original position or in this new out-of-phase position. Just a couple of new holes in the inner part of the body that allow me to assemble intjis way and bingo!!
