Neutral Light Goes In & Out
indianabiker
I have a 79 cm400t and it's always had problems with the neutral light. When I charge the battery it comes on and also when I first turn the bike on it works. But after I start riding it go comes and goes and pretty soon it doesn't come on at all but if I let the bike sit for a day and fire it up it comes on. Any ideas? This is my first motorcycle so I'm learning. I don't have the slightest :)
I kind of have the same problem.
But mine works fine when the bike is just turned on.
But after I start the bike it doesn't work at all.
Yea I would think a short or a worn wire/loose connection. Also check out the bulb, maybe it's going. I don't know how the neutral light is activated but on the cb550s, when you shift in N, there is a stator and rotor set up so that when the rotor meets the stator, when the shifter is in N, it completes a circuit, activating the N light. Maybe after riding the bike the stator or rotor gets dirty from grease, dust, dirt, whatever and the circuit can't be completed because the two points aren't able to touch.
Just a thought..
I just chased a bad neutral down myself, the light would flicker and go out depending on the handlebar position. If the bundle is tight to the light housing it will give a bit, but over time it may break down the wire internally. Ohm it out from the switch to the connection, and the connector to the headlight neutral light.
