Here's the generic instruction which should work ok. I'm assuming all you want to do is get the ears out and put clipons on. Also assuming the stock handlebars have been removed.
Remove front wheel. Bike has to be supported obviously. Leave the front fender on to keep the fork lowers together. Remove the brake caliper from the fork leg.
Losen the bolts on the lower triple tree.
Pull the forks down through the tree.
Unbolt the headlight bucket from the ears. If there are turn signals in there, you'll need to remove them.
Are their gaitors on the fork tubes? If so, do they connect to the fork lowers and headlight ears? If so you'll have to sort out going without them or clamping them to the fork tubes by putting some thick rubber under them as a spacer and a hose clamp to keep them in place on the fork tubes.
Ears should fall off if they haven't already
Slide forks back up a bit.
Put new headlight brackets on first.
Then put on clipons.
Slide forks back up and tighten up the bolts on the triple tree a bit. Get the front wheel and brake back on. Get the forks back up into final position and snug up the bolts. Loctite is always nice.
Position headlight ears and put bolts back into bucket.
Position clipons.
If all this is too much, do what LOTS of folks do and spend $30 on a nice set of clubmans
